Beast $4500 build thoughts.
Solved by brob,
Get rid of the four HDD the SSDs that you have is plenty and change the two Titan X's for two 980 TI's. You shave off $2,265.99 and you can put it towards higher capacity SSDs and a custom water loop.
Exchanging the two Titan X for 980 Ti would save at most $300 total.
How do you know the storage needed by the OP? Even so, dropping the four hdd saves $240.
My arithmetic suggests a total savings of just $540, not over $2,000. Is there something else that is included in the "savings"?
