I don't think you can get a custom loop for 200 dollar
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/500355-water-cooling/#findComment-6681585
I have a $200 budget for watercooling. I don't want an AIO, but I also don't want to spend too much on a custom loop. I am wondering what the best kit would be, and I also want clear tubing. It has to fit inside my define s case.
get the EKWB Predator, an AIO with custom watercooling loop grade of components :)
http://www.amazon.com/EK-XLC-Predator-All-In-One-Liquid-Cooling/dp/B014CVMMI0 (240 mm rad)
if you have 260$ to spend, this is definitely worth the extra.
http://www.amazon.com/EK-XLC-Predator-All-In-One-Liquid-Cooling/dp/B014CVMP6Y (360 mm rad)
https://linustechtips.com/topic/500355-water-cooling/#findComment-6681604
i second this one. the EKWB parts mean upgrading your loop in the future will be as easy as can be, and the quality is amazing.
https://linustechtips.com/topic/500355-water-cooling/#findComment-6681709
^ That .. and they also have other kits for a bit more price with 240mm rad which is a better option than 120mm.
I'd personally go with EK Predator, much higher quality this starter level custom loop.
CPU: Intel Core i7-6700K /Cooler: Custom Loop /Motherboard: ASUS ROG Maximus VIII Formula /Memory: G.Skill Trident Z 64GB (3000 MHz) /GPU: Zotac GTX 1080 AMP! Extreme
Storage: 2x 500GB Samsung 850 EVO SSD + 120GB Kingston v300 SSD + 4TB WD Black + 3x 2TB WD Red + 500GB Seagate Barracuda /Chassis: Corsair 900D /OS: Win 10 x64
All powered by Corsair AX1200i
https://linustechtips.com/topic/500355-water-cooling/#findComment-6683221
