PG27AQ - need your help asap : )
Hey
i want to buy this monitor and i can pre order it now
i have no idea how this monitor will be and i dont want to buy something i have never dealt with (had pg278q b4)
you can see my rig in the signature /profile
main games that i play are TheWitcher 3/ Black Ops 3 / Killing Floor 2 and such...
i heard windows 10 got issues running 4K at 27' or s omething like that
and also heard that many games not optimized for this resolution so i must make sure b4 i approve this how good this model and if its worth it
if you dont think its worth . my only "other option" is the PG279Q
thanks in advance .
Fractal Design Define R5~ Asus Maximus VII HERO~ i7-4790k@ 4.7 GHz. ~ GTX 980 Ti G1 Gaming ~ 16 GB Kingston HyperX 2400 HZ. ~ Samsung 850EVO 1TB SSD ~ Asus CD/DVD reader/writer ~ Coolermaster V Series 1000W~ Noctua NH-D15+ Noctua NH-A14 FLX x3-   BenQ's XL2420G Monitor  - Steelseries APEX M800 / Zowie EC2-A / Zowie G-SR
https://linustechtips.com/topic/500095-pg27aq-need-your-help-asap/
Do not get the 4k monitor, you will not be able to play on it with decent frame rates. Go with the 1440p 144hz Ips panel instead for better results :)
he has a 980ti ? what are you on about. he will get decent frame rates. the pg278q is a good monitor
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
And? I still would prefer smoother rates with better picture and color quality than 4k :o 2k is still an amazing. 4k is not recommended unless you have SLI or Crossfire of the highest end GPU :o
he will get decent frame rates... and with 4k he cans go down to 1440p if he likes. win win
1
With a single card id lean more towards a 1440p monitor. With a single card at 4k your looking at 30fps to less in most games. I have 2 980ti's and I might just past 60fps.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
i dont think one would pay top dollar for pc components only to play at Decent rates, you want high end rates to the best possible experince, and 4k hardware just is not there yet. And why go down to 1440p if you can just save money and buy a native 1440p monitor that can be smoother @ 100-144 hz and ips :P doesn't make much sense lo
how do you spell lol wrong ?
and why go down to 1440 ? so he can use 4k in the native os obviously. makes perfect sense *lol*
1
hey guys thanks for the respone
i guess the pg279q is the best option
the 4k scares me because i never dealt with that high res before.
i know gsync suppose to make gaming better but still it wont help much if i get 30-40fps
seems like pg279q is the best option
too bad it has dust issues/massive BLB issues and more...
