i help with a dell inspiron 530 motherboard
hello , i am VERY new here and still learning this forum, plz dont ban me if this is in the Wong place.
the dell motherboard i have is a g33m02 and it used to work but i had to heat up the case to get it to power up,
it used to turn on the PSU and after wile it would turn on the motherboard and it would POST and boot, now it is head in to winter and
i cant get it to the heat i need without doing damage. it dost even turn on the PSU. i have the original case with all the front panel swichs working. i also tested the
PSU and it works just fine. i am thinking the mother board it's self has a somewhat broken power circuit some where. i am open to ideas, if i need to replace it i like it
the new one to be under 40 $ USD. thank you for your time,
Hello and welcome! B)
There are quite a few of them on ebay for around your budget;
