Corsair fans are fairly good.
But if u really want top notch fans, get Noctua ones. NFF12 for radiators and heatsinks, NFS12 for cases.
I'd also recommend shoping at places like
Scan
Aria
Dabs
Novatech
OverclockersUK
if ur in the UK when searching for PC components. Places like Maplin and PCworld tend to be pricey, and have limited choices.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/497695-best-pc-fan/#findComment-6651916
Is this a good pc fan? http://www.maplin.co.uk/p/corsair-af120-quiet-edition-120mm-fan-n82qq
Sorry if in wrong section, new to the forums :)
Corsair AF fans are not bad and they definitly look great, but they are pretty loud compared to other fans and the amount of pressure they can "produce" isn't that great either. The airflow is pretty good tho.
If you want to use this as a case intake or outtake, where there isn't much structure blocking the airflow it's fine to use this fan.
If you want something of much higher quality, which is much quieter and cools your components a lot better, get something else, like a be Quiet Silent Wings 2 or Noctua NF-F12
https://linustechtips.com/topic/497695-best-pc-fan/#findComment-6651921
Is this just for a case fan for air flow or for a rad? Those Corsair fans are "ok". They are 3 pin and their motors can be a little noisy (buzzy) I found.
Assuming you need a case fan for air flow, these are better: http://www.deepcool.com/product/gamerstorm/2014-09/6_996.shtml (Deepcool GF120)
Very high quality, PWM (4 pin) control, they flow lots of air and are very quiet. I'm running two of them in my system and they work better than the 140mm Fractal Design fans I had before. They're also very inexpensive, considering they perform like Noctuas. ;)
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/497695-best-pc-fan/#findComment-6651926
