Posted December 2, 2015 Ok so I had conflicting sound drivers so I disabled the Nvidia driver and kept the Realtek driver, my headphones are still registered as an audio device and work fine, unfortunately, my speakers and TV speakers are no longer registered, not even under 'disconnected' devices, any ideas on how to get them up and running again? Thanks. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 2, 2015 Reinstall the driver... Its basically the communicator between your hardware and software, no wonder theyre not being recognized 4690K // 212 EVO // Z97-PRO // Vengeance 16GB // GTX 770 GTX 970 // MX100 128GB // Toshiba 1TB // Air 540 // HX650 Logitech G502 RGB // Corsair K65 RGB (MX Red) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 2, 2015 Wait, you said your speakers and tv speakers. Isn't your tv plugged into your graphics card through HDMI? You need the audio drivers for that. Are your speakers plugged into your TV or directly to the motherboard? What was conflicting before? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 2, 2015 Author I reinstalled the driver just now, no change, sadly. And yeah TV is plugged into GPU HDMI, but speakers are straight into the mobo and still isn't being recognized Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 2, 2015 Author disabling the realtek drivers and leaving the Nvidia driver enabled allows only the TV to be recognized.... real... Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 3, 2015 I reinstalled the driver just now, no change, sadly. And yeah TV is plugged into GPU HDMI, but speakers are straight into the mobo and still isn't being recognized disabling the realtek drivers and leaving the Nvidia driver enabled allows only the TV to be recognized.... real... LOL you have to have both enabled. What happens when you have both enabled? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 3, 2015 disabling the realtek drivers and leaving the Nvidia driver enabled allows only the TV to be recognized.... real... enabled HDMI audio, and rear 3.5 gets disabled. Put priority on 3.5 rear, and HDMI gets borked. If you want to have both, you will need to create a new playback device that utilizes both HDMI output and 3.5mm rear output. http://www.addictivetips.com/windows-tips/how-to-play-audio-through-hdmi-speakers-simultaneously-in-windows-7/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
