Triple Monitor Stand
BSpendlove
I've been whizzing through Amazon and other sites, interested in buying a steady triple monitor stand which isn't overly expensive. I don't feel comfortable buying one for £30 but have seen a few with decent reviews around £80-100. This is a perfect price point for my situation.
11047596_946940645377958_559466095361129
So as you can see, I have got the monitor stands but need to take them home with me today but I would like to spend a bit of extra cash to make the three screens neat onto one stand. I've been currently looking at:
http://www.amazon.co.uk/Duronic-DM753-Triple-Monitor-Bracket/dp/B00P0X8R70/ref=sr_1_2?ie=UTF8&qid=1448961886&sr=8-2&keywords=Triple+Monitor+Stand
http://www.amazon.co.uk/MOOL-Professional-Triple-Mount-Bracket/dp/B00UBOLSME/ref=sr_1_5?ie=UTF8&qid=1448961886&sr=8-5&keywords=Triple+Monitor+Stand
So with the DM753, I keep reading about the plating at the bottom can sometimes lift off a tiny bit with triple monitors. These 3 monitors are a deal I grabbed from work, 3 x AW2310's. Around 7-7.2KG although I feel they are a bit heavier. (I am weak... haha)
So my IDEAL budget is around £80 but if I get a suggestion around £110... I might have to go for it and think of the outcome.
EDIT: I also believe the screens to be 23" Widescreens.
I'm going to put a link to my PC specs which actually aren't my PC specs and I cry myself to sleep everyday so I can have these PC specs but I can't afford these PC specs so PC specs PC specs PC specs PC specs PC specs PC specs.
Thank you, I will have a look into it and read about it. :)
I have the Artic z3 it seems to do the job quite well and my favorite part is it mounts to the desk itself so there is no worry of things falling over/there is minimal roml taken up on your desk by the base.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
System Specs
So I went ahead with that Novatech V2 Stand, The monitors have the VESA 100m which this stand does take. It should arrive tomorrow around 3ish.
I'll post some pictures when it arrives and give my opinion on the assembling etc..
Thank you for your help! :D
