Any reason you want the 6600K? Typically in a gaming build the most expensive part is the GPU
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/496539-first-build/#findComment-6640019
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($59.86 @ Amazon)
Motherboard: Gigabyte GA-H170N-WIFI Mini ITX LGA1151 Motherboard  ($102.99 @ SuperBiiz)
Memory: Kingston 8GB (1 x 8GB) DDR4-2133 Memory  ($36.55 @ SuperBiiz)
Storage: Kingston HyperX Fury 240GB 2.5" Solid State Drive  ($89.99 @ Adorama)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($179.99 @ Newegg)
Case: Thermaltake Core V1 Mini ITX Tower Case  ($36.55 @ SuperBiiz)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan  ($5.99 @ NCIX US)
Monitor: LG 20M37D-B 60Hz 19.5" Monitor  ($87.99 @ SuperBiiz)
Total: $965.53
Generated by PCPartPicker 2015-11-30 21:42 EST-0500
Slightly better performance, equal price.
Moist
https://linustechtips.com/topic/496539-first-build/#findComment-6640035
960 is only good for MOBOs and stuff like that, most other things have to be on medium-low. Recomened 16 GB of ram. some other tweaks could be made here and there.
https://linustechtips.com/topic/496539-first-build/#findComment-6640036
Does that mobo support overclocking? If not, then you don't need a k-skew cpu. It'd also be better to utilize dual-channel technology and get a 2x4 kit of ram instead of a single 8gb stick. And finally, for the $200 price point, the r9 380 tends to be the better card. And you'll need more storage space in the future, so a 1tb hdd should be a future addition.
CPU - Intel i7-4790k | CPU Cooler - Cooler Master Hyper 212 EVO | Motherboard - Gigabyte GA-Z97-HD3 (Rev 2.0) | RAM - G.Skill Ripjaws X 16GB (2x8) DDR3-1866 | Storage - Samsung 850 EVO 500GB SSD | Graphics Card - EVGA GeForce GTX 980ti SC | Case - Fractal Design Define R5 w/Window (Black) | PSU - EVGA 750W B2 | Display - Acer K272HUL | Keyboard - E-Element RGB | Mouse - Logitech g502 | Sound - Klipsch ProMedia 2.1/Fostex TH-x00/Sennheiser HD595
https://linustechtips.com/topic/496539-first-build/#findComment-6640052
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($54.99 @ Micro Center)
Motherboard: Gigabyte GA-Z170N-WIFI Mini ITX LGA1151 Motherboard  ($124.99 @ SuperBiiz)
Case: Thermaltake Core V1 Mini ITX Tower Case  ($29.99 @ Newegg)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan  ($4.99 @ Newegg)
Total: $965.98
Generated by PCPartPicker 2015-11-30 21:49 EST-0500
https://linustechtips.com/topic/496539-first-build/#findComment-6640090
No I'll switch the mobo
https://linustechtips.com/topic/496539-first-build/#findComment-6640120
Sorry, but as a 2gb 960 owner, that is utter hogwash. Sure, a 380 will beat it, but I still max Planetside 2, World of Tanks, Warthunder, MGSV, Elite:Dangerous, and many more. Also, 8gb is fine for todays standards.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/496539-first-build/#findComment-6640165
