Review my build. (1,500$) Everything is ordered (1-2 days to edit order during payment verification). Review my build
True, it's in the budget but I have rethought my approach. If I spoil him with top of the line GPU now he will never know the struggle or appreciate it.
Going for a mid tier GPU here intentionally so he doesn't take it for granite when he gets the new ones in June?
Is the card I selected a good choice ( I only have experience with MSI 970 and EVGA 980 TI's). Anything in that price range is fine. Hell I may downgrade him to a 960 but that might just be cruel.
If you can afford it, don't go to GTX 960/R9 380 level. It's a very significant downgrade.
This is the best bang for the buck build with a bit cheaper GPU, I kept a black/white colour scheme so it also looks very nice:
(if he needs 8GB of VRAM you can go R9 390 instead, the 290X is a little faster, but it has 4GB, I don't think anyone needs that since 4GB is perfectly fine even for 1440p)
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($299.99 @ Newegg)
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler ($89.90 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($89.99 @ Newegg)
Memory: G.Skill Sniper Gaming Series 16GB (2 x 8GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Intel 535 Series 240GB 2.5" Solid State Drive ($69.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($44.99 @ Newegg)
Video Card: XFX Radeon R9 290X 4GB Double Dissipation Video Card ($293.98 @ Newegg)
Case: NZXT H440 (Glossy White/Black) ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: XFX Core Edition 850W 80+ Bronze Certified ATX Power Supply ($54.99 @ Newegg)
Total: $1103.81
Generated by PCPartPicker 2015-11-30 21:27 EST-0500
