I am currently building a very high end pc so I need high end fans. witch are the best?
(high static pressure is preferred)
Noctua NF-F12s or be quiet! Silent Wings 2.
Other systems I've built:
https://linustechtips.com/topic/495526-best-fan/#findComment-6629655
Noiseblockers NB-eLoop B12-P (http://www.performance-pcs.com/noiseblocker-nb-eloop-b12-p-120mm-x-25mm-ultra-silent-bionic-blade-pwm-fan-800-2000-rpm.html) They look cool c: A friend has one and they're great he says.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/495526-best-fan/#findComment-6629683
If you want static pressure fans as intakes, be prepared to run them at high speeds and thus incur more noise. A fan like the NF-F12 will do well as an intake, but only if run at moderate or high speeds; the shallow blade angle prevents optimum performance at lower speeds.
https://linustechtips.com/topic/495526-best-fan/#findComment-6633014
Please list your specs.
https://linustechtips.com/topic/495526-best-fan/#findComment-6633063
5960x(watercooled) gtx 980ti 16 gb ram
That left out the most important information for fan recommendations: case and heatsink/radiators.
https://linustechtips.com/topic/495526-best-fan/#findComment-6655176
oh sorry i have an nzxt phantom 410 yet i plan on switching to the phanteks enthoo luxe and i have a swifttech h240x and i plan to add a thick single rad in the back so i can add my GPUs
https://linustechtips.com/topic/495526-best-fan/#findComment-6663124
