Hi guys,
  Planning on building a PC in the next week or so, and before I order all the parts with the fantastic black friday deals (!), I just wanted to ensure everything was compatible.
CPU - Intel i7 4790k
Mo/bo - ASUS z97-a
G/Card - MSI GTX 980ti (1178Mhz)
RAM - Corsair 16GB (2x8GB) LP
CPU cooler - Dark Rock Pro 3
Case - be Quiet! Silent Base 800 (BLACK)
PSU - Corsair RM650 Gold 80+
Storage - Seagate 2TB SSHD
OS - Windows 10
Monitor - Acer XB270hu (PREDATOR) brpz
It'll cost a little under £2000, which is a lot, so I want to make sure everything will slot in nicely together. I know the issues with the Dark Rock Pro 3 being just about the beefiest cooler i can get (Silence is a big thing for me).
If someone could just let me know if it'll all fit together and is all compatible.
Thanks in advance!
https://linustechtips.com/topic/495473-is-my-build-compatible/
-snip-
 yesa as long as the rams ddr3. but you should use pcpartpicker as that will tell you if its compatible automatically
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/495473-is-my-build-compatible/#findComment-6629085
yes but why buy a k when you buy a cheap aircooler?
get a i5-4460 or a i5-4690 non K
Dark Rock Pro 3 isn't cheap?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/495473-is-my-build-compatible/#findComment-6629094
What do you mean, the Dark Rock Pro 3 is a great cooler...
https://linustechtips.com/topic/495473-is-my-build-compatible/#findComment-6629097
You've severely misread something...
The dark rock pro is NOT a cheap aircooler. Or did you mean WHEN you can buy a cheap aircooler, in which case the answer is obvious.
calm ur tits, i misread it
https://linustechtips.com/topic/495473-is-my-build-compatible/#findComment-6629129
Rather than slate the first comment can we try and focus on the quality/compatibility of the build? xD
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/495473-is-my-build-compatible/#findComment-6629142
