What would be the difference would it make if there were 2 Identical CPUs and they have only a .5 GHz clock difference? Would it be a big difference?
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/495355-overclocking-difference/
How identical? Is everything the same besides clock speed?
https://linustechtips.com/topic/495355-overclocking-difference/#findComment-6627834
Yes, everything is the same
https://linustechtips.com/topic/495355-overclocking-difference/#findComment-6627840
It won't make a huge difference at all.
https://linustechtips.com/topic/495355-overclocking-difference/#findComment-6627848
More than likely around 1-5% in combined and physics portion of benchmarks. That is about what I have seen going from 4.3 to 4.5.
https://linustechtips.com/topic/495355-overclocking-difference/#findComment-6627924
Intel or AMD?
And difference in what? Gaming, web browsing, MSFT Paint, video encoding?
You need to state a use case, as .5GHz is meaningless in most things people do with computers.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/495355-overclocking-difference/#findComment-6628346
