Help me choose monitor!
ozisike
is this monitor good? Idk anything about monitors this is just one my friend got. i just recently built  a new gaming cpu and i need a new monitor with it!
http://www.amazon.com/Asus-VG248QE-24-Inch-LED-Lit-Monitor/dp/B00B2HH7G0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1432528656&sr=1-1&keywords=2ms+1080p+144+display+port
EDIT :Can spend about 230 on a monitor.
are you only playing shooters?
or you're watching movies,tv shows and brows a tons...
I do watch movies and shit on it yeah, And no i mobas also.
then I would recommend you to go with a monitor that has an ips panel
