What Monitor will give me the best display
iamdrinster
Hi so its the holiday season and Im looking to upgrade to a 23 or 24 inch monitor Yes those ranges only for im a lil bit on the a budget.
So there are so many monitor models and I need your advice on what to choice from the list I have.
The main features im looking for a monitor is its Bright Display, Yes I Bright Display, since ive encountered a monitor before which was ACER and its somehow a lil bit of dim lighting and I want my next monitor to be a brighter one so i could see the details. And also it will be for gaming, and pretty much editing. I wont be needing a 144hz display as it will really hurt my wallet. You could also suggest a 27" display but its just a way for me to consider :) lets still focus on these items.
List of possible monitor
Asus 23 (VX239H)
Asus 24 (VS247H)
BenQ 24 (GL2460)
BenQ 24 (RL2455HM)
LG 25 (25UM65)
Viewsonic 24 (VX2452MH)
Viewsonic 24 (VX2456ML)
As you Noticed this is only my choices, "LG" is a temporary choice as it is over my budget but please feel free to tell me your insights,
Intel Core i5 - 6400 <> Msi B150A Gaming Pro <> Msi Gtx 970 Gaming <> G.Skill Ripjaw 4 16Gb DDR4 2400mhz
<> Corsair CX500M <> 160 & 250 Seagate HDD <> Aerocool Strike X (Casing) <>
Any help guys?
