Hello, I'm still kind of a newbie to computer building. Does this PSU have the correct CPU power connector?
Corsair CX750
http://store.hp.com/us/en/pdp/Laptops/hp-pavilion-15t---windows-7-laptop-l8v62av-1?jumpid=Laptops_Finder_PDP
Asus Sabertooth  Z170 Mark 1https://www.asus.com/Motherboards/SABERTOOTH-Z170-MARK-1/
https://linustechtips.com/topic/494236-psu-compatibility-help/
Yes, but I would recommend an XFX PSU instead: http://pcpartpicker.com/part/xfx-power-supply-xfxts550w
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/494236-psu-compatibility-help/#findComment-6616761
Um question why does the CX 750 link go to an hp laptop? Also don't get CX
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=416 here's a review of how bad that PSU is.
"CWT really had an off day on this one, didn't they? The whole point for soldering comes off today, for some dreadful work to a level I don't usually see from them. Another point comes off for that big flake of whatever the heck it was on the PCB. Another point for sleeve bearings in the fan. Half a point comes off for second tier capacitors. Finally, half a point for the damaged wires. 6"
-Jonnyguru
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/494236-psu-compatibility-help/#findComment-6616771
if you have the money for a sabertooth motherboard, you have the money for a quality PSU.
i'll drop you some picks to choose from:
http://pcpartpicker.com/part/seasonic-power-supply-s12ii620bronze "the budget option"
http://pcpartpicker.com/part/evga-power-supply-220p20750x1 "the fancy option"
http://pcpartpicker.com/part/corsair-power-supply-cp9020074 "the i lost my mind and got a motherboard with thermal armor option"
https://linustechtips.com/topic/494236-psu-compatibility-help/#findComment-6616841
