Why does coax cable come into my house instead of Ethernet?
Solved by thekeemo,
The coax carries the signal from the ISP
you use the modem to get ethernet which you then connect to the router
Featured Topics
RotaryRoach ·
Posted in Cases and Mods3 -
Eyuni ·
Posted in Troubleshooting0 -
Sarra ·
Posted in Storage Devices1 -
1
5
JeanPMikhael ·
Posted in Laptops and Pre-Built Systems4 -
CornholioQ ·
Posted in CPUs, Motherboards, and Memory1 -
1
2
