So I want to buy an XLR to RCA cable if I get a new speaker. I'm deciding between these two: http://www.amazon.com/BuyCheapCables%C2%AE-Cable-Male--Microphone-Cables/dp/B005HS96KU/ or http://www.amazon.com/PPRC-X05-Professional-Audio-Cable-Female/dp/B000V1RLI2/. Do they both deliver the same sound quality. 1 has two xlr cables (white and red) and two rca cables (white and red) while the other one has one xlr cable to one rca cable.
Numbre
https://linustechtips.com/topic/494164-xlr-to-rca-cable/
what speaker are you getting?
speakers that have XLR usually also have unbalanced RCA...
https://linustechtips.com/topic/494164-xlr-to-rca-cable/#findComment-6616182
that's an XLR/TRS jack
you can use a TRS to RCA cable and it will probably be cheaper
its the same sound quality whatever you use
https://linustechtips.com/topic/494164-xlr-to-rca-cable/#findComment-6616244
