Help rog swift with and card ?
AmbientFives
Hey guys my friend is selling me is gsync rog swift for 450 cad so i cant say no the only thibg is can i play on it with my amd fury x without anysort of bug ? For sure gsync wont work right but can i use it normally without any issue and benefiting from the 144hz 1ms 2560x1440p display still?
Sorrt for ma english am french canadian
The G-sync wont work but all the other features should work just fine. (Haven't heard anyone havning troubles with AMD cards so)
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
yes , you can still use it as a normal display
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
Sorrt for ma english am french Canadian
You can use it but I wouldn't suggest it at all.
You won't have ANY image scaling functions since the monitor does not have a hardware scaler built in (the Gsync scaler requires the Nvidia control panel to adjust monitor settings), and you will have limited ability to adjust color options as well.
it will just function as a 144hz monitor.  And is this the PG278Q or PG279Q?  There are TWO ROG Swifts.
There have also been reported issues getting Gsync monitors to run at 144hz on AMD cards, since (drumroll, please) they were designed for Nvidia hardware.  I don't know if this was addressed in AMD BIOS updates or in catalyst driver updates or not.
Before you jump on it, I'd check freesync deals on black friday. A new tn 144hz freesync monitor probably isn't much more.
I'm not sure with the Canadian dollar though, I could be wrong.
CPU: Ryzen 7 3700x,  MOBO: ASUS TUF X570 Gaming Pro wifi, CPU cooler: Noctua U12a RAM: Gskill Ripjaws V @3600mhz,  GPU: Asus Tuf RTX OC 3080 PSU: Seasonic Focus GX850 CASE: Lian Li Lancool 2 Mesh Storage: 500 GB Inland Premium M.2,  Sandisk Ultra Plus II 256 GB & 120 GB
