http://pcpartpicker.com/p/cpWXD3
So this is my part list my first time building a pc i took a small case beacuse i travel alot and this was the only one i could find.
Is there anyway i could improve this build? Would be nice if i could lower the price or find better parts.
I want to be able to play the witcher 3/Csgo/league/skyrim/fallout 4 on medium settings or have 60 fps on low settings.
Or is there any special deals on black friday that i could use for my pc
And any noob information that i should know about when building my first pc
https://linustechtips.com/topic/492484-building-my-first-px/
1- Some variants of the 750 Ti are 20 dollars cheaper get them.
2-Get a single 1 8GB stick so that you can add another later on.
3-You don't need DVD/CD player to install windows so unless you need them for something else don't get them
4-Get a i3 2 cores are not enough today
Motherboard: MSI H81I Mini ITX LGA1150 Motherboard  ($53.55 @ SuperBiiz)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($31.45 @ SuperBiiz)
Video Card: MSI GeForce GTX 750 Ti 2GB TWIN FROZR Video Card  ($89.99 @ Newegg)
Case: Lian-Li PC-TU200B Mini ITX Tower Case  ($133.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($29.99 @ NCIX US)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($84.98 @ OutletPC)
Total: $568.04
Generated by PCPartPicker 2015-11-25 18:59 EST-0500
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/492484-building-my-first-px/#findComment-6601516
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($104.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($39.10 @ SuperBiiz)
Total: $568.04
Tfw your case is more expensive that your graphics card or your CPU...
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/492484-building-my-first-px/#findComment-6601544
https://www.reddit.com/r/microsoftsoftwareswap/
That page is a great place to get Windows for $35. It's all legit and I've used it multiple times and it's always gone perfectly fine. It saves you fifty bucks, very worth it. So with that extra money get an SSD and definitely get a cheaper case.
https://linustechtips.com/topic/492484-building-my-first-px/#findComment-6601552
He insists on it even though I personally recommend the elite 130/110
https://linustechtips.com/topic/492484-building-my-first-px/#findComment-6603704
Does it have to be ITX?
Also don't get a G3258, it's having more and more trouble in some recent games due to being a dual core
PCPartPicker part list: http://pcpartpicker.com/p/T7R2P6
Price breakdown by merchant: http://pcpartpicker.com/p/T7R2P6/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($159.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($35.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ Newegg)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($219.99 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Amazon)
Total: $572.39
Generated by PCPartPicker 2015-11-26 03:13 EST-0500
PCPartPicker part list: http://pcpartpicker.com/p/Hh8M99
Price breakdown by merchant: http://pcpartpicker.com/p/Hh8M99/by_merchant/
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($96.99 @ SuperBiiz)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  ($284.99 @ SuperBiiz)
Total: $574.39
Generated by PCPartPicker 2015-11-26 03:14 EST-0500
You could either go with an i3 + 390 or an i5 + 380
the 390 is going to game better at higher resolutions, while the 380 rig is going to have higher fps in games that are CPU heavy like CoH or Total war
overall the i3 rig is probably better for pure gaming, and the i5 better for productivity
https://linustechtips.com/topic/492484-building-my-first-px/#findComment-6603912
The case is pretty cheap here in sweden around $40-60
Get it it's pretty easy to work on and has good value.
https://linustechtips.com/topic/492484-building-my-first-px/#findComment-6604809
