Is there a big difference in gaming between those 2 CPU's ? I dont plan on overclocking and i will have a r9 390gpu to go with either one of them.
Im not sure if the 4690k is worth it if it doesnt make that much of a difference :D
If you are not overclocking just get the 4460
https://linustechtips.com/topic/492036-4460-or-4690k-help/#findComment-6596231
Is the 4460 enough for the 390 ? Or is it bottle-necking something im really bad at this :D
no it wont bottleneck it
the 4460 will basically perform the same, the whole point of the K processor is to be overclocked
https://linustechtips.com/topic/492036-4460-or-4690k-help/#findComment-6596238
A 4460 bottlenecks nothing.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/492036-4460-or-4690k-help/#findComment-6596239
What do you think about my graphics card choice ?
I was thining about gtx970 or the r9 390 but i heard the 390 is better can anyone confirm ?
Yes, the 390 has better performance. Just note the power requirements of the 390.
A society's accepted views of the world surrounding said society is both the making and undoing of society itself.
“While one person hesitates because he feels inferior, the other is busy making mistakes and becoming superior.” - Henry C. Link
https://linustechtips.com/topic/492036-4460-or-4690k-help/#findComment-6596311
600 Watts should be enough for the 4660 and the r390 and 2hdds and 1 ssd right ?
yes
https://linustechtips.com/topic/492036-4460-or-4690k-help/#findComment-6596520
It's more than enough I think.
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/492036-4460-or-4690k-help/#findComment-6596535
In the UK, the difference is about £30. So depending on your region, I would just go for the 4690K.
You may not overclock now, but you may in the future should you need it. My 4690K is sitting at stock, but at least I have the option to in the future. If you buy a 4460, then you don't have the option at all, you'll need to purchase a new processor and possibly a new motherboard, depending on what you buy now.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/492036-4460-or-4690k-help/#findComment-6596778
