So i am going to be making a new gaming pc. Ill be playing games like fallout 4 and gta v. Ill be playing those games at 4k and 1080p. I will also be doing some overclocking. Is this a good build for my needs? Will I need a better cpu to run these games at a good framerate like 70 fps+? Will there be any bottlenecking with the cpu I chose? Leave any and all opinions and suggestions in the comments please. My busget is $1500-$1600
Heres a link to the build:
https://pcpartpicker.com/user/TRambo/saved/PP6WGX
https://linustechtips.com/topic/491073-first-pc-build/
The I5-4690K is just barely out of bottleneck range, if you want no bottlenecks whatsoever, go with a FX-8320/8350 or a i7/e3-1231
But first, let's talk about parallel universes.
Intel i7-4790k undervolt, NVidia EVGA GTX 980Ti SC Reference, NVidia EVGA GTX 480 SC Reference, ASUS Z97-A/USB3.1, SK Hynix SL308 240GB, WD Green 2TB, Hynix 1333 8GB (4x2), XFX Core Pro 850w, NH-U12S, 4x NF-F12's, Sennheiser HD 558's, Blue Yeti, Corsair K70 (red), Logitech MX Master, XBox One Controller, ASUS VG248QE 144Hz, HP 2010i
https://linustechtips.com/topic/491073-first-pc-build/#findComment-6584525
You're joking, right?
(The answer is yes)
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/491073-first-pc-build/#findComment-6584675
https://linustechtips.com/topic/491073-first-pc-build/#findComment-6584776
Would a gtx 980ti and an i5-4690k run fallout 4 at around 35-50 fps? Would there be any bottlenecks?
Ill be runnkng the game at 4k
yes,
turn off AA
turn god rays to low
shadow draw distance to high
shadow quality to med
give teh 980ti a clock to 1450+ MHZ - and you should get a solid 60fps (I do)
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
https://linustechtips.com/topic/491073-first-pc-build/#findComment-6584881
