sound card or usb headphones
Solved by Guest,
Hello I have been thinking whats is better usb headphones or buy sound card and 3.5mm jack headphones. for headphones I were thinking about Kingston HyperX Cloud II or this sound card some 3.5mm headphones .
Well the USB soundcard that is included with the HyperX CLoud II are known to not show the potential of the headphones.
But i have a few questions
1. What motherboard do you have (nvm i see your sig)
2. What soundcard are you considering because this "or this sound card some 3.5mm headphones." made 0 sense to me.
EDIT: The onboard audio on that motherboard is fine for a pair of HyperX Cloud and its better than the USB soundcard on the HyperX Cloud II.
