After many forum posts and lots of research, I came up with these lists for a $1000 and $1500 PC, whichever one I can afford by next fall, so here they are! They need to last 4-5 years becuase in college if I want to go where I want to and take the courses I want it will literally be the laughing stock of the class :P. The lists are also made up or very reliable parts from reliable manufacturer's as not all of us have bins of GPU's (Stares at Linus' closet).
$1000 PC:
PCPartPicker part list: http://ca.pcpartpicker.com/p/w7wRcf
Price breakdown by merchant: http://ca.pcpartpicker.com/p/w7wRcf/by_merchant/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($239.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($81.98 @ DirectCanada)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory  ($54.95 @ NCIX)
Storage: OCZ Trion 100 120GB 2.5" Solid State Drive  ($55.98 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($58.71 @ Vuugo)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  ($429.98 @ Newegg Canada)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($89.50 @ Vuugo)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($105.54 @ DirectCanada)
Total: $1116.63
Generated by PCPartPicker 2015-11-22 19:19 EST-0500
$1500 PC:
PCPartPicker part list: http://ca.pcpartpicker.com/p/hsZ699
Price breakdown by merchant: http://ca.pcpartpicker.com/p/hsZ699/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($411.71 @ Vuugo)
Motherboard: Gigabyte GA-Z170X-Gaming 3 ATX LGA1151 Motherboard  ($182.00 @ Vuugo)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($125.98 @ Newegg Canada)
Storage: Sandisk Z400s 128GB 2.5" Solid State Drive  ($54.99 @ NCIX)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($114.98 @ Newegg Canada)
Total: $1483.89
Generated by PCPartPicker 2015-11-22 19:25 EST-0500
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/490348-pc-build-for-myself/
GO with the first, the second isnt that much better
https://linustechtips.com/topic/490348-pc-build-for-myself/#findComment-6576060
Id go with the second one but grab the unlocked i5, i7 is un-necessary for gaming
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/490348-pc-build-for-myself/#findComment-6576066
CPU is eh, the only i5's I consider at this point are the 4460 and 4690k. Also, cooler on both? Don't spend 1000+ on a PC and use stock cooler.
Go for a 4460 and spend a little bit more on a cooler, maybe a Hyper 212 Evo or something similar.
https://linustechtips.com/topic/490348-pc-build-for-myself/#findComment-6576068
I don't really want to overclock (Warranty really) And I chose the 4590 because it's 15 dollars more than the 4460. CPU prices in Canada are just crazy AF.
AXIOM
https://linustechtips.com/topic/490348-pc-build-for-myself/#findComment-6576090
$1000 PC:
Total: $1116.63
$1500 PC:
Total: $1483.89
First of all mate, on what resolution would you like to game at? Also defenately get the first build as you don't really need the second one! Also get the i5 4460, it's better in terms of price to performance than the 4590! Good luck :)
https://linustechtips.com/topic/490348-pc-build-for-myself/#findComment-6577312
Probably 1080P or 1440p if i can afford a monitor thats in 1440. I even go dual 1080p if I can afford it
AXIOM
https://linustechtips.com/topic/490348-pc-build-for-myself/#findComment-6579244
