Help me decide a monitor.
Drugumbu
Hey guys.
So i need help in choosing a good 1080p monitor so i want to know which one should i go :
http://www.amazon.com/HP-Pavilion-27xw-Backlit-Monitor/dp/B00TQQN4WU/ref=lp_1292115011_du_10_map?s=pc&ie=UTF8&qid=1448015186&sr=1-10
http://www.amazon.com/dp/B00B17C5KO/ref=psdc_1292115011_t1_B00TQQN4WU
Or anyother 1080p 27" monitor you guys wanna suggest in this price point ?
I wanna add this that i am slightly tilting towards the Hp one cus its newer than than Asus also the reviews on that monitor are awesome but still i want to ask you guys which one should i go for and why?
I have that second monitor in a 21:9 aspect ratio. I love how it looks!
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
Hey guys.
What are the purposes of the monitor?
Mainly for gaming
How long have you been using it ? How is your overall experience in terms of gaming ?
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 1TB Crucial P5 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 10 Pro x64
Absolutely loving the 21:9 ratio! It's incredible how games look on a widescreen.
idk if the one you linked is 21:9 too, can't find it anywhere. But I'm loving the monitor so much. Also, the audio is by Bang & Olufsen, they have beast audio! (in-case you'd use it, I don't)
Those looks good but i am thinking for an IPS panel rahter than TN (are those TN ?) because i will use it to watch movies too. Also picked 27" for that purpose too :D
IPS is better for movies but it isn't good for gaming. 144Hz TN panels have a much lower response time which is great for gaming purposes. 144Hz is very good for smooth gaming.
BenQ says 75hz not 144... Can it be OC'd?
Sorry, yes you're right it's 75Hz i don't think you can overclock it though.
i know that TN will be better but the current monitor i have has a response time of 8 or maybe 10 ms. This doesnt feel weird to me tbh so
Go with ASUS. Lower response time. Better for gaming!  :)
