Fallout 4 glitch, please help!
Solved by Senzelian,
Now that I look at it, the setting seems to go back to the way it was each time I reset.
Is there a way to stop that from doing so?
Yeah, you could set the Fallout4prefs.ini to read only, so it can't be changed anymore by the system.
You should be able to find the Fallout4prefs.ini in Documents\myGames\Fallout4\
So first change the settings, then set it to read only. You should also be able to find the wetness setting somewhere in the Fallout4prefs.ini
If you can find it, set it to 0.
