Should be enough for 960 SLI.
No you cannot SLI a 960 and 970.
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/487941-power-supply-questions/#findComment-6548932
Thank you, can you SLI an EVGA 960 and a Gigabyte 960?
Yes you can. Brand doesn't matter when SLI'ing. The chip does.
https://linustechtips.com/topic/487941-power-supply-questions/#findComment-6548952
Hi my rig is as follows;
CPU: FX-8350 @ 4 Ghz
GPU: Gigabyte GTX 960
Motherboard: ASUS Sabertooth r2.0
SSD: 32Gb SanDisk
HDD: 1TB WDD
PSU: 630W Be Quiet
First off, I wondering if my PSU is big enough to add a second 960?
Secondly, can you SLI a 960 and a 970?
You should be fine.
https://linustechtips.com/topic/487941-power-supply-questions/#findComment-6549412
