theses are my specs
Case: Thermaltake Black Versa II Mid Tower Case
Motherboard: ASUSTeK Computer INC. V-P7H55E (LGA1156)
CPU: Intel Core i7 870 @ 2.93GHz
Graphics: EVGA GeForce GTX 760 Superclocked ACX 2GB
Memory: 16.0GB Dual-Channel DDR3 @ 665MHz
Power Supply: have a spair thermaltake 500watt that came with case
Cooling: Thermaltake Water 2.0 Performer CPU Liquid Cooling System and thermaltake 120mm fan that came with case and soon to gain Arctic Cooling 120mm F12 PWM Fan x3
and will this power supply be ok
http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_354&products_id=21713
https://linustechtips.com/topic/48784-will-this-power-supply-be-enough/
If it provides enough amperage on the 12V rail, yes. And that Corsair unit does. Don't know about the Thermaltake unit though since you didn't mention any model.
Yep.
PC Specs:  2x GTX 550 ti in SLI - Intel i7 2600k @ 3.4Ghz - Thermaltake Overseer Case - 8 GB Corsair Vengeance Ram - 1TB Harddrive - 500 Watt PSU that came with my old prebuilt pc lawl -  ASUS P8P67 EVO
Peripherals:  Razer Deathadder Black Edition - Razer Arctosa Keyboard - Logitech G53 Headset
Cool song of the day: Chief Keef - Round da Rosey    Changed my profile pic again...                                        Mountain Dew is good. So are video games and music. Oh and unicorns.
The 500 watt unit that comes with your case will likely be good enough.
I would recommend that Super Flower Golden Green 600w I had recommended in your other thread. It's a much higher-end unit than the DSA-II unit that the Corsair CX is based off of. For only $10 more, it's a much better investment. http://www.itestate.com.au/pages/product/pdt_product_detail.faces?BeanName=productDetailAction&pcode=16156
Otherwise, if you are only limited to PCCG, I would look at the Antec HCG 520. http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_535&products_id=15135
It's a Seasonic S12II Bronze internally and is better build than the CX.
oh wow that is a no brainer. the super flower is much much better. even a bronze super flower compared to corsair bronze psu`s.
