PC Case Airflow help!
Go to solution Solved by Nexxus,
Don't see a point then in taking rad of then, I could just flip fans. Here is a picture of my setup!
http://imgur.com/3W8XEqS
yes just do that, the way it was on my system the fans were against the case, and then rad in under the fans (thats how you would want it for intake cause the fans are RIGHT against the source of air it needs to "feed" from the way youi currently have it isnt the greatest for intake airflow.
But yes just turn your fans around the other way and you are golden...also look for dust against the rad/take a chance to blast the rad fins with air when you got the fans off.
Hello everyone again... :)
I have the NZXT H440 and was wonder is my airflow pointing the right way for the best optimization, I'm unsure what way the fans are blowing, but the arrows represent the way the fan stickers are pointing towards.
Sorry about the bad annotations and also all the questions (more to come xD)
Might add this later...
https://linustechtips.com/topic/487837-pc-case-airflow-help/
I have an H440 too. I have 2 fans at the top but they push air out. I have them running at a lower RPM so I have more intake than exhaust.
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547404
Id have the top fans exhausting out the top if it was me
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547411
umm need a bit more info then that... are you using an AIO CPU cooler or air? and the direction the arrows are pointing is the direction the sticker is facing? not the air flow of the fan...?
Yes the way the arrows are pointing is the way the stickers on the fan are pointing, also the top fans are my watercooling fans (Corsair H105).
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547415
ya put your rad fans on exhaust I had those on intake on a umm...corsair 600d or wahtever
This was the result
So unless you got a custom dust filter...ya
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547422
Not to mention you are probably suffocating things its going to be easier to push tair out of the h440s top vents then drag air in...I also run blower cards so most of the air thats going though my rad isnt hot air.
System Specs
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547424
It's my water cooler fans...
so? you can still exhaust out the top, thats what I would do, cool are comes in, and gets pushed through the rad by the fans cooling it down, and stopping dust getting into the rad fins
you could even intake from the back if you like too, though it might help to just keep it as exhaust and get rid of any warm air from the GPU in the case although the rear outtake should take care of that
you could try intake from the bottom, but depends how warm your PSU gets and if its on a dusty surface
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547433
This was the result
Hey, thanks for the advice. By putting it on "exhaust" does that mean flipping the water cooler? Sorry not good with fans in general!
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547523
No cause your rad hoses are going to be screwy.
Do it properly unmount the entire thing, put the rad against the case and then the fans on the underside of the rad. at least thats how I had to do it in the h100i
A friend might be helpful cause I found it a pain in the dick to line everything up
System Specs
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547532
turn your fans around so the arrow points to the top
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547543
Thanks, So flips the radiator + the fans or just flip the fans or do you mean for the fans to be on the opposite side of the rad (currently rad is on the top of case and fans are visible, with the sticker also visible)?
Fan's are the only pc component I never paid much attention too, so not that great :D
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547555
dont flip anything
step 1 unmount the rads and the fans
step 2 (if needed) take the fans off the rad
step 3 mount rad on top of case
step 4 mount fans on underside of rad making sure air is pushing out (ok you will have to flip the fans over...)
Even spinning the fan by hand you should be able to tell which way its gonna push air if you put your hand infront of the blades
System Specs
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547604
How do you know which way the fan spin?
The direction its pushing air just feels...more "pushy" you can feel the air being pushed into your palm
System Specs
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547626
Most fan as an arrow on it to tell you which way the air is blowing.
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547639
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547648
System Specs
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547785
For sure, got a friend going to talk me through all this via skype. I appreciate the help and hopefully my temp drops :D
https://linustechtips.com/topic/487837-pc-case-airflow-help/#findComment-6547843
