Hey guys so i recently got Fallout 4 and i've found my PC is overheating with the CPU getting to temps up too in the 80 degrees Celsius range.
I currently run a horrible little CPU cooler that helps not at all, i just cleaned the PC out a bit getting all the dust out which brought it down to 74 degrees when playing.
Another thing i am planning to do is overclock this CPU because i've heard how much potential it has.
Currently i'm running an FX-8350, a Gigabyte R9 280X and a gigabyte board (Of some sort, forgot the name) and a Zalman Z11+ case.
Here are my choices. (Please not the prices are in AUD)
Cooler Master Seidon 120V Plus $69
Corsair Hydro Series H75 $99
Cooler Master Nepton 280L $129
Corsair Hydro H100i $158
Corsair Hydro H110i $169
Thanks for the help!
https://linustechtips.com/topic/486263-what-water-cooler/
h110i or X61
https://linustechtips.com/topic/486263-what-water-cooler/#findComment-6525659
An air CPU cooler is usually slightly cheaper and offers similar performance. I'd suggest the CRYORIG R1 Ultimate.
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/486263-what-water-cooler/#findComment-6525672
If you can the Cooler Master Hyper 212X is an awesome cooler and should have no problem cooling the 8350 & only costs like 30$ USD.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/486263-what-water-cooler/#findComment-6525680
x61, but I think Frys.com has an h80i GT for $100, I would know cause that what I'm using xD Good luck!
PROJECT Simplifyi5-4690K OC'd @ 4.2 GHz | GTX 760 | Ballistix Sport 8 GB | ASRock Z97M-ITX/AC | Corsair H80i GT | SilverStone SG13B |
UPCOMING| RX Series GPU | Mechanical Keyboard | Mirrorless Camera |
VIDEO KIT: Canon SX520 HS | Opteka "Glidecam" | Zoom H5 | Shure SM58 |
I'm 16 and I like to think I'm good at videography.
https://linustechtips.com/topic/486263-what-water-cooler/#findComment-6525730
