Logitech z906 audio
MoshMain
I have a z906 speaker set, and i have a little problem. When im hearing pop music and all that good stuff, it sounds great, but when i'm hearing rock, it just sounds terrible. Any suggestions of settings or something i can do??
-Thanks.
What kind of soundcard do you have?
Dont think i actually have one..
Maybe its running on my motherboard
You have like three options. 1. EQ to get the sounds you desire more which may be annoying. 2. Get a soundcard which tbh probably will not do all that much or 3. Upgrade your speakers which i recommend fully. Take a look at the corsair speakers.
My Corsair speakers are amazing.. :)
