My friend mentioned that there might be condensation issues with this.
It gets below 0 here in the winter and I wanted to make an outdoor watercooler for the great temps. I would obviously be using anti-freeze, and the unit would be below my computer. I would be running the loop straight to my CPU and out the case using plastic tubing and an all-copper waterblock.
So, is there going to be a condensation issue, and what can I do to prevent that?
edit: still gotta figure out where pumps going
But first, let's talk about parallel universes.
Intel i7-4790k undervolt, NVidia EVGA GTX 980Ti SC Reference, NVidia EVGA GTX 480 SC Reference, ASUS Z97-A/USB3.1, SK Hynix SL308 240GB, WD Green 2TB, Hynix 1333 8GB (4x2), XFX Core Pro 850w, NH-U12S, 4x NF-F12's, Sennheiser HD 558's, Blue Yeti, Corsair K70 (red), Logitech MX Master, XBox One Controller, ASUS VG248QE 144Hz, HP 2010i
https://linustechtips.com/topic/483493-outdoors-cooler/
You would need insulation on the tubing and the motherboard
what about that?
https://linustechtips.com/topic/483493-outdoors-cooler/#findComment-6485825
yes the temperature will be lower than ambient causing condensation to form on your tubing and waterblocks
you need to use insulation on all your tubing and waterblocks, similar to how linus prepped this PC for phase change, you need to do the same for your CPU:
https://linustechtips.com/topic/483493-outdoors-cooler/#findComment-6485827
Well, do you know a way to start about doing that and where to look for the stuff to do that? Insulation for tubes...
I might scrap the idea. Putting a gum-type substance on a motherboard might not be a great idea.
(RMA...)
https://linustechtips.com/topic/483493-outdoors-cooler/#findComment-6485907
(RMA...)
it takes a ton of preparation to prevent condensation like that
tbh I would just buy the largest radiator possible and have it indoors
https://linustechtips.com/topic/483493-outdoors-cooler/#findComment-6487009
