Making PC Silent on idle
Temuka
Hello guys! I'm coming from my previous thread:
http://linustechtips.com/main/topic/477158-new-case-builtstill-humming-noisemaybe-psu-fault/
So I decided to purchase EVGA G2 750W in terms of silence in psu,what also I can add/change in my system to make it silent on idle? Maybe some kind of good quality fan controller ?? Because I have no idea what rpm are case and cooler fans running.... Maybe also change cooler or cooler fans ? Any help is appreciated,thanks in advance
GPU - R9 390 Nitro   ///   CPU - Intel 3570K   ///   RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB)   ///   HDD - 3TB + 1TB / SSD - Crucial MX100 256GB
PSU - EVGA 750 G2   ///   Case - be quiet! - Silent Base 800   ///   Corsair A70 Cooler
Your case fans are very good.
Most you could do is get like a Noctua or BeQuiet! Air cooler
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
back fan,which is 120mm is kinda noisy in comparison with front ones,which are 140mm,because of that,I thought to buy fan controller and set fans to 500RPM,is it ok ?
How good are you with a soldering iron? I have a simple design for a DIY adjustable fan controller. Mine turns off my PC fans when idle and turns them on at about 40 degrees. I can web browse all day without fan.
I'm really bad in that :( For me it's better to buy and just install it.....
Any other ideas guys ?
