Hey guys. So recently i've been having frame drops issues with my ASUS Strix gtx 970 4gb. While gaming, i get random gpu usage drops to 0% for a fraction of a second. This is in games like The Witcher 3, GTA V, Assassins Creed Black Flag, and more recent titles. I have already installed all latest drivers needed. I also don't have the games on their highest settings.
My PC is very well ventilated so there's no heat problems. Also, my vram usage usually averages out at 60% most of the time so it shouldn't be the nvidia problem with the 3.5gb of the 970s.
Here are my PC specs:
CPU: i5 4690k 3.50 ghz
GPU: Strix GTX 970 4gb
Mobo: Z97s SLI Krait Edition
Ram: 2 x 8gb Kingston HyperX Fury 1866 mhz
PSU: Corsair 1000w Platinum
I need help fast cause this is really annoying. Thanks in advance.
P.S. I've also posted this on Toms Hardware
https://linustechtips.com/topic/475687-gtx-970-frame-drops/
snip
Don't use the lastest drivers, use the most stable ones, 353.62 is the most stable one in the past 6 months from my knowledge, so if your using the one for say battlefront beta game ready don't
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/475687-gtx-970-frame-drops/#findComment-6374470
Nvidia drivers being Nvidia drivers?
what about the other 8 million of people using the GTX 970 with the same gameready driver that are NOT having this issue? :huh:
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/475687-gtx-970-frame-drops/#findComment-6374669
https://linustechtips.com/topic/475687-gtx-970-frame-drops/#findComment-6374686
Ive already tried that. Same problem.
Well it is an asus, so I'm going to blame the gpu itself, so it's likely defective
https://linustechtips.com/topic/475687-gtx-970-frame-drops/#findComment-6374779
i have the same gpu but did not experience any drop frame rate esp. on witcher 3.using version 355.98
Rig: CPU: Intel I7 4790k @ 4.5 ghz | MOBO: MSI Z97 Gaming 3 | RAM: 4x4 gigs Kingston Fury 1600 ddr3 | GPU: MSI Geforce GTX 1070 Gaming X PSU: Seasonic M12ii-620 Evo Edition | HDD: 1 TB WD, 500 GB WD | SSD: Kingston SSD now 240 and 120 GB CASE: In Win 303 RGB edition | Mouse: Corsair m65 pro | Keyboard: Roccat Ryos MK | Headset: Hyper X Cloud Pro  | Monitor: LG 29um58-P Ultrawide monitor.
https://linustechtips.com/topic/475687-gtx-970-frame-drops/#findComment-6375035
VRAM probably gets into the 0.5G territory - tone down AA and or AF
https://linustechtips.com/topic/475687-gtx-970-frame-drops/#findComment-6375475
maybe install this hotfix driver if you havnt already OP and see if it fixes it?:
https://forums.geforce.com/default/topic/885014/geforce-drivers/announcing-geforce-hotfix-driver-358-59/
https://linustechtips.com/topic/475687-gtx-970-frame-drops/#findComment-6375989
