Problem of Durability.. IEM's
Fluffinator
Currently I have a problem finding a earphone that won't break on me. I can go about a month without the apple earpods breaking, the longest earpods I've had were the Seinheiser Momentum IEM's which lasted about five months. I tried looking at something reallt expensive in the past like custom IEM's but I feel like I would break them.. So I'm looking for suggestions for a decent pair of IEM's under $150 I listen to mostly rock such as this.
http://m.youtube.com/watch?v=j2p_w409y-o
Here's the spot where my IEM's break
http://imgur.com/Dkq7TRd
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
My Shure SE215 has this plastic 2005 style large ass connector that i man handled.
It still works.
Also cable detachable so i can swap if broken.
Im currently looking to buy a set of sennheiser momentum on ears :D.
They have detachable cables as well :D:D:D:D.
Do they have to be IEMs? For the price range you've listed (Under $150) you can get some pretty damn good headsets and headphones alike.
It still works.
I've heard good things about the SE-215 however I feel like the over ear musician style isn't for me.
Has to be IEM's I already have a lot of different headphones.
Yea it took me quite a while to get used to em.
Plus my clear ones are getting green xD.
You take a look at the Sennheiser Momentum IEMs? People speak volumes about them; super rich sound quality - Durable and not too expensive. Like £90 which is something like $140.
**I forgot you mentioned you already owned a pair of those, MY BAD :ph34r: <_< **
why would you replace headphones just because connector is broken. Buy a bigger connector and solder it on to it. Maybe ad a spring to the connector so that it would, not bend so much
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
It's a better idea to get those sturdy metal jacks and solder it on them and maybe add some braided cable
Not the jack size/shape you want but this is what I am talking about
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
I can solder but, you can't solder that there's actually no sound coming out of one of the earbuds it's not the connector it's the entire wire inside is split. I could get a new wire and try my luck but that is far too much work.
It's an hour of work tops. I don't think you get paid $150 an hour :D  It's just my suggestion. Good quality headphones break only at the cable and there is little the manufacturer can do as different people apply different pressure to the cable. Just try cutting a little bit further than where the cable was split and it should fix it.
Honestly don't have enough time and I'm looking for a excuse to upgrade lol.
On another note, anyone see this http://www.amazon.com/gp/aw/d/B00ELAM8LE/ref=psd_mlt_nbc_B00N3RFFV6_r I've beenlooking at it haven't heard much about it.
On another note, anyone see this http://www.amazon.com/gp/aw/d/B00ELAM8LE/ref=psd_mlt_nbc_B00N3RFFV6_r I've beenlooking at it haven't heard mich about it.
You can't re solder IEM cables, the wire that they use on the inside isn't your regular copper cable... PLEASE don't attempt to re solder them unless you have a really good soldering kit and have soldered them before.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
I thought so, I didn't look at the video because it was for regular sized headphones and I sort of have a idea of what I'm doing somewhat.. lol
RHA MA750
Yeah that was the amazon link actually, they any good?
Looks like a very strong jack
Yeah it does, it looks promising but I've never heard anything about these.
They seem to be very good. Recommended by Innerfidelity. Here is a review by Zeos for the "i"version. Don't really know what that upgrade is:
Internets Machine: Intel 4690k w/ Be Quiet! Pure Rock 4.7Ghz. MSI Krait z97. 16GB Crucial Ballistix Sport Ram. MSI GTX 970 SLI 1520mhz. 500GB Samsung EVO 840  & 3TB WD Blue Drive. Rosewill 1000w Modular PSU. Corsair Air 540
My Beats Yo: Desktop:SMSL SA-160 Amp, KEF Q100 w/ Dayton 100w Sub Theater: Micca MB42X-C x3, MB42X x2, COVO-S x2 w/Dayton 120w Sub Headphones:  HIFiMan HE-400i, PSB M4U2, Philips Fidelio X2, Modded Fostex T50RP, ATH-M50, NVX XPT100, Phillips SHP9500, Pioneer SE-A1000, Hyper X Cloud 1&2, CHC Silverado, Superlux 668B
RHA is an awesome brand, a few of the musicians I regularly play with recommend them.
Stille (Desktop)
Evoo Gaming 15"
Ohhhhh these are over ear designed. Not my thing, feel like I would feel like a dork wearing them. How about the Paradigm Shift E3, I've seen those aswell.
Never used them before, but the reviews seem to say that they are good quality earbuds. Really though, if you want accurate sound quality, you have to put your money into stage monitors like the Sennheiser IE60, Shure SE215 or something similar.
Stille (Desktop)
Evoo Gaming 15"
Design doesn't equal better sound, they are designed like that because musicians prefer it for better isolation means and the over the ear design is just all around better for musicians alike whether it be less likely to fall out or better concealed or whatever. However that wouldn't affect the sound quality. For me I want something not geared towards musician, no over the ear design, doesn't mean I won't get a good sound experience just means I'm not a fan of the design.
Sorry on mobile atm. The i version is the same earphone with an inline Mic and volume control. Joker and zeos gave it excellent reviews. Believe they come with a 3 year warranty as well.
If you want a durable IEM, I think you'll have to go with over the ear style with removable cable. Most straight cable IEM are just not durable enough especially if you broke a momentum in ear in 5 months.
SE215 is an option, other (more expensive) option are SE535, UE900S, W40, W4R and SE425
