OK,I got everything, other than one question:
If a car is going at 15mph, how will it's air resistance compare when going 30mph? And 45mph?
Now I know it will be larger, but I could not tell the relationship.
https://linustechtips.com/topic/474662-physics-problem-help/
nvm
https://linustechtips.com/topic/474662-physics-problem-help/#findComment-6360477
will  be 4 times as much
equation for air resistance uses v^2, so v1^2/v2^2 gives the multiplier
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/474662-physics-problem-help/#findComment-6360481
Just put "my car doesn't have gas in it so it can't even do 15mph" and you are going to be fine.
https://linustechtips.com/topic/474662-physics-problem-help/#findComment-6360494
That's what I was thinking
https://linustechtips.com/topic/474662-physics-problem-help/#findComment-6360499
since the air density and object do not change, and the coefficient is a constant, it is only dependent on velocity
Solitaire.
https://linustechtips.com/topic/474662-physics-problem-help/#findComment-6360500
Is this literally the whole question, no table or anything? How many marks are available and what level are you working at?
Yes, based on the lab we did determining air resistance for coffee filters.
Marks?
Level is 11th grade honors physics
https://linustechtips.com/topic/474662-physics-problem-help/#findComment-6360505
OK, that makes sense.
We just use that equation today for our lab, so I guess I could have applied it to this question (which is in the lab)
https://linustechtips.com/topic/474662-physics-problem-help/#findComment-6360515
