Give me a moment to fix some things... @jamiecooper welcome to the forums and please remember to follow your threads :D I presume the budget is £750? I also presume this is for 1080p gaming.
http://uk.pcpartpicker.com/p/vbH9Mp I just made some edits, slightly cheaper CPU and smaller form factor coupled with a better PSU.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/471755-first-pc/#findComment-6325130
Is this a good first pc build??
http://uk.pcpartpicker.com/p/wbzKjX
Just change the awful CX PSU.. other than that, system is good.
https://linustechtips.com/topic/471755-first-pc/#findComment-6325134
how is the CX bad psu? its a good psu for casual builds
30 degree ambient temp or high will make it not start, shitty chinese caps rated at 85 deg operating temps instead of japanese 105 deg ones...etc
Corsair themselves say that it should be for basic builds only :P
USEFUL LINKS:
https://linustechtips.com/topic/471755-first-pc/#findComment-6325150
and that's bad for casual builds?
https://linustechtips.com/topic/471755-first-pc/#findComment-6325156
Because when the end user decides to upgrade the rig (Which they may or may not do) the CX PSU wouldn't be the safest thing to put under a load from a gaming rig.
USEFUL LINKS:
https://linustechtips.com/topic/471755-first-pc/#findComment-6325171
