So I'm building a sky lake computer and my case is an inwin 805 and I my motherboard is going to be a asus maximus viii hero and the cpu is a i7 6700k. And basically I want a air cooler (preferably a noctua) which is no taller then 145mm. The reason why I am going for a air cooler is because I'm afraid of leaks in a closed loop cooler. And I've seen closed loop coolers leak.
https://linustechtips.com/topic/471233-help-me-pls/
https://pcpartpicker.com/part/cryorig-cpu-cooler-h7
Oh, welcome to the forums @Shamawowow (Nice nickname xD). For future reference, please remember to follow your own threads as to not miss out on answers. Also, this thread should be in the Air Cooling subforum, should it not?
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/471233-help-me-pls/#findComment-6318579
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/471233-help-me-pls/#findComment-6318591
closed loops aint that bad but any way the hyper 212 is a solid cooler for the price
He asked for a noctua, and that it be no larger than 145mm to fit in his case. The hyper 212 firstly, isn't noctua, and secondly is 160mm tall. More than 15mm too tall to fit in his case, thirdly. People need to stop fanboying over the 212. For its price, there's not much better, but for 10$ more you can get something significantly better, and for 20$ more you can get something far, far better and quieter.
https://linustechtips.com/topic/471233-help-me-pls/#findComment-6318601
-snip-
I second the CRYORIG H7, very good cooler from what I've heard. Almost used one instead of the H100i in my system in my sig :)
Other systems I've built:
https://linustechtips.com/topic/471233-help-me-pls/#findComment-6318638
Why 145mm when the case supports up to 156mm?
https://linustechtips.com/topic/471233-help-me-pls/#findComment-6321589
Because the mother board height, cpu height added up together is about 7mm thick so I want to leave some space and besides the
Noctua d15 is 165mm I think and useless I'm wrong pls correct me
The cpu cooler clearance of 156mm is measured from the cpu socket.
https://linustechtips.com/topic/471233-help-me-pls/#findComment-6345894
  • 2 weeks later...
