Help me choose a processor....
Solved by Analog,
From these two the 6700K. It will be cheaper and will perform as good if not better compared to 5820K, since it has a higher stock clock. Nevertheless, if all you really want to do is just game and general day-to-day stuff, you can easily save some money and buy the i5 6600K, because almost all games only utilize up to 4 cores and hyperthreading isn't really going to add to the gaming performance of your rig. You can easily save those extra 100-150$ and spend them instead on an i7 on a better graphics card.
