Tube and Fitting Compatibility
Go to solution Solved by W-L,
@red773
Something like theses don't have built in fittings and use a G1/4 fitting to allow you to use the EKWB fittings on it for any tubing size:
http://www.performance-pcs.com/bitspower-matte-black-quick-disconnected-male-with-inner-g1-4.html
http://www.performance-pcs.com/bitspower-matte-black-quick-disconnected-female-with-inner-g1-4.html
The tubing and fittings will work but not the QDC that one has a fitting built in with the size 1/2" ID 5/8" OD which wouldn't work.
It looks like the QDC and the tubing are compatible, but the QDC already has a compression fitting built in so there's no need for the EK fitting.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
@red773
