I'm trying to pull the count of how many videos is uploaded onto an YouTube channel. I'm having problems, i want to show The number of videos uploaded to the channel. like this does with other statistics
<?php
$data = json_decode($data, true);
$stats_data = $data['entry']['yt$statistics'];
echo 'lastWebAccess = '.$stats_data['lastWebAccess'].'<br />';
echo 'subscriberCount = '.$stats_data['subscriberCount'].'<br />';
echo 'videoWatchCount = '.$stats_data['videoWatchCount'].'<br />';
echo 'viewCount = '.$stats_data['viewCount'].'<br />';
echo 'totalUploadViews = '.$stats_data['totalUploadViews'].'<br />';
ive been trying and looking for help all over the internet help me plz
update this is what i have come up with but it seams it doesn'twork
<?php
$json = json_decode($jsonString);
print($json->data->totalItems . "\n");
https://linustechtips.com/topic/46669-youtube-videocount-help/
You are decoding the wrong part of the JSON object I think.
Looking at the raw JSON code, you probably need this part:
{"rel":"http://gdata.youtube.com/schemas/2007#user.uploads","href":"http://gdata.youtube.com/feeds/api/users/imsparky15/uploads","countHint":242},
Using this code:
<?php$data = file_get_contents('http://gdata.youtube.com/feeds/api/users/ImSparky15?alt=json');$data = json_decode($data, true);$stats_data = $data['entry']['gd$feedLink'];echo 'uploadcount = '.$stats_data[4]['countHint'].'<br />';?>
gets me:
uploadcount = 242<br />
which, judging from your YT channel, seems to be the number of uploaded videos
on your channel.
EDIT: Just saw your edit, I'll have a look at that as well.
EDIT 2:
Yeah, something doesn't look quite right in your second version. I recommend using
this code to get a closer look at the array which you get after decoding the json
object. This will allow you to really analyse the whole thing and take it apart into
those pieces which are relevant to you.
<?php$jsonString = file_get_contents('http://gdata.youtube.com/feeds/api/users/ImSparky15?alt=json');$json = json_decode($jsonString);echo print_r($json,true);?>
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-617411
Using this code:
gets me:
on your channel.
thank you so much this has been bugging me all day
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-617424
Happy to help. :)
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-617449
I'll have a look.
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-617639
I'll allow myself a double post so that you'll get the update notification ;)
I've taken a look at it, but seeing as how I've never worked with the YT API
before I think it would just take too long for me to work through all of that. I
know PHP and a bit of JSON, but the Youtube API is new to me, and I just don't have
the time to read all that documentation at the moment to really get his solution
to work (sorry).
Basically the idea of his suggestion is that you don't need to get the JSON object
but can instead make a direct request for the information to the server.
I highly recommend reading the linked documentation thoroughly, I'm pretty sure that
what you need to know is in there, I just don't have the time to work through all of
that at the moment. Or ask the guy on SO, he should be able to help as well.
What I have found out is that you will probably need your channel ID and your
account id, which you should be able to get at this page on YT.
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-617746
to work (sorry).
Ty I'm also new to YT api it was just confusing me thanks for all your help and the links
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-617763
I done what the other user said on the other site and got the same results, the only difference I see is the use of channel Id, but I'm confused on how to pull the video count in this document
https://www.googleapis.com/youtube/v3/channels?part=statistics&id={CHANNEL_ID}&fields=items%2Fstatistics&key={YOUR_API_KEY}
Response
"items": [
"statistics": {
"viewCount": "433592",
"commentCount": "30",
"subscriberCount": "2270",
"hiddenSubscriberCount": false,
"videoCount": "242"
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-617951
Good to know it's working. :)
Indeed extracting individual variables from this seems a bit more laborious than directly
parsing a JSON object (unless you could get it to directly and only return the number "242",
which would make things quite neat).
If that's not possible and you still wanted to process this in PHP you could store it in
a document and then parse that with regular expressions. But TBH that seems a bit inelegant
IMO.
So as far as I can tell at the moment the first version is still a bit more elegant for
processing data in PHP. But as said, I have no experience with YT's API, so there might
be a better way still.
EDIT: Discard, of course you can parse this as JSON. That's the whole point.
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-618193
IMO.
Ty I'm having problems with the second version, the only benefit I see with it is using user ID, but the 1st version was easier to code in php
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-618334
Wrote this a while back in python... worked back then haven't tested it recently though
def getUserChannelData(request, userID):
    try:
        path = "https://gdata.youtube.com/feeds/api/users/"+userID
        xmlDoc = urllib2.urlopen(path)
        tree = etree.parse(xmlDoc)
        root = tree.getroot()
        tmpDataHolder = tree.findall("{http://schemas.google.com/g/2005}feedLink")
        upload_count=0
        for lnk in tmpDataHolder:
             if 'uploads' in lnk.attrib['href']:
                 upload_count = lnk.attrib['countHint']
    except:
        er='Invalid User Name Provided'
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-618389
Posting a solution from PM for the public. This works for me:
<?php$data = file_get_contents('https://www.googleapis.com/youtube/v3/channels?part=statistics&id=UCRO8jVq4et04MN-k8vOhlFg&fields=items%2Fstatistics&key=AIzaSyChIuEZJgrU9E1AViVCHyqqqBkb8dJ6yKA');$data = json_decode($data, true);$stats_data = $data['items']['0']['statistics'];echo 'uploadcount = '.$stats_data['videoCount'];?>
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-618567
I'm getting this error with that code http://img202.imageshack.us/img202/9858/9v4s.jpg
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-619142
Ah yes, I stumbled upon that one myself. You need to uncomment the following
line in your php.ini:
For a Linux system (such as mine):
extension=openssl.so
And for a Windows environment (haven't tried this one personally, don't have
a Windows machine):
extension=php_openssl.dll
See this post on SO about it.
Depending on your server I am not sure if you actually have access to php.ini,
in which case this might get tricky. If that's the case, I'm not quite sure
how to get around that at the moment.
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-619267
a Windows machine):
Thank you for all the help I will try this in the morning as it 3am in the UK and I'm sure it's much later were u are
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-619311
4 AM. I'm actually already in bed, but curiosity got the better of me and
I just had to check my feed one last time. :D
Anyway, good night!
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-619317
Anyway, good night!
happy to tel u that its working now that i have uncomment openssl in my server php.ini
thanks for all the help
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-621072
is there a way to add (number_format), so the number is easier to read on output?
DW sorted it out
<?php
echo number_format($stats_data['viewCount']);
https://linustechtips.com/topic/46669-youtube-videocount-help/#findComment-621949
