So having read up on fan coloring, it seems universally agreed upon, that dyeing is a superior way compared to painting.
However despite having found a guide on OC3D (http://forum.overclock3d.net/showthread.php?t=35185), I still haven't a clue on how to take the fan apart. The guide seems to deal exclusively with the aftermath. Has anyone out there successfully dissembled a noctua fan, and have or can take some pictures or give a few pointers?
https://linustechtips.com/topic/466113-noctua-fan-dissembly/
SACRILEGE!
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254490
only some of them can be disassembled
if there is a tiny round magnet or c clip on the fan hub then you can, otherwise you will break the fan trying to remove the rotor
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254503
I want to do that too, but no idea how to properly disassemble one.
My Rig:
CPU: Intel i7 5820K @4.3 GHz; Mobo: MSI X99A SLI Plus; Cooler: Cryorig H5 Ultimate; RAM: 16GB HyperX Fury Black; GPU: MSI R9 380 4GB; Case: Fractal Design Define R5 Black w/ Window; SSD: Samsung 850 EVO 256GB and 500GB; HDD: WD Blue 1TB; PSU: EVGA 750W P2
Peripherals:
Monitor: LG 29UM57; Headset: HyperX Cloud II; Keyboard: Gamdias Hermes Mechanical; Mouse: Zowie EC2-A
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254506
if there is a tiny round magnet on the fan hub then you can, otherwise you will break the fan trying to remove the rotor
Which ones?
My Rig:
Peripherals:
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254507
Which ones?
look under the sticker and see if it is solid plastic or there is something you can remove
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254524
Never Mind. On their website it says they're not supposed to be taken apart.
My Rig:
Peripherals:
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254525
yup
http://linustechtips.com/main/topic/6553-a-warning-for-those-thinking-of-dying-noctua-nf-f12s/
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254575
They wouldnt run as good as before, unbalance because of the paint. Its not recommended and will void your warranty.
I successfully hacked 127.0.0.1! Now I cant turn on my computer :/
6700K - z170 Pro Gaming - Samsung 850 Pro 256GB - WD Black 1TB - WD Green 3TB - External Hard drive 3TB - Zotac GTX 970 Amp! Core Edition - Fractal Define R5 - RM650 - Razer BW Chroma - Roccat Tyon Lasermouse
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6254600
It doesn't have anything to do with the rear magnet but there is a lock-ring underneath the bearing. It sits on the inside of the bearing and can not be accessed from the rear side (all Noctua fans are closed on the rear side in order to seal off the bearing). Due to the lock-ring, it takes a lot of force to pull out the rotor, you will usually end up breaking either the rotor or the frame. Even if you manage to do it, you will ruin the top sealing of the bearing: http://www.noctua.at/main.php?show=faqs_single&faqs_id=61
https://linustechtips.com/topic/466113-noctua-fan-dissembly/#findComment-6257319
