Hey guys i am building a new Pc mainly for gaming. This is what i have so far
CPU: Intel Core i7-5960X 3.0GHz 8-Core Processor
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler
Motherboard: MSI X99A GODLIKE GAMING EATX LGA2011-3 Motherboard
Memory: Corsair Dominator Platinum 32GB (4 x 8GB) DDR4-2400 Memory
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive
Video Card: EVGA GeForce GTX Titan X 12GB Superclocked Video Card (2-Way SLI)
Power Supply: Corsair AX1500i 1500W 80+ Titanium Certified Fully-Modular ATX Power Supply
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Operating System: Microsoft Windows 10 Pro OEM (64-bit)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard
Mouse: Corsair SCIMITAR RGB Wired Optical Mouse
Headphones: SteelSeries Elite Prism 7.1 Channel Headset
Now my main problem is monitors. I do not know if i should either go 4k or 3 3440x1440p monitors.
Any suggestions would be appreciated with a reason why
https://linustechtips.com/topic/465968-need-advice-on-this-build/
Swap out the Titans for 980 ti's Save yourself some money. Unless you need the Vram.
Plus this system is OVERKILL for gaming.
Burn that stupidly overpriced machine with fire.
You could literally cut your price down by $1600-$2000....
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Yeah i know its kind of overkill but id like to to use the upcoming x34 acer monitor and get a steady 100 fps
Use PCPartPicker.com
Tons of AAA games do not use more then 4 cores and the ones that do, do not do it very well. Also, at higher resolutions CPUs become less dependant, for example, a FX8350 would not bottleneck a 980Ti at 2160p. Also, what is the exact budget? Games, do not need more then 8GBa of RAM, however, I suggest atleast 16GBs since you can afford it and games are starting to use more then 8 ect ect.
useless
useless
useless
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($104.20 @ B&H)
Motherboard: MSI Z170 Krait Gaming ATX LGA1151 Motherboard  ($134.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($17.89 @ OutletPC)
Operating System: Microsoft Windows 10 Pro OEM (64-bit)  ($139.75 @ OutletPC)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard  ($174.99 @ Newegg)
Mouse: Corsair SCIMITAR RGB Wired Optical Mouse  ($79.99 @ Amazon)
Headphones: SteelSeries Elite Prism 7.1 Channel Headset  ($199.99 @ B&H)
Total: $3495.28
Generated by PCPartPicker 2015-10-12 13:49 EDT-0400
Don't fucking throw the most expensive parts you can in there. You're only gaming you only need 4 cores. Not 8.
useless
useless
useless
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($366.99 @ B&H)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($103.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($168.63 @ Amazon)
Storage: Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive  ($149.99 @ Newegg)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case  ($138.59 @ Amazon)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($146.66 @ Newegg)
Other: 2x 980Ti Hall of Fame ($1400.00)
Total: $3495.28
3x 3440x1440, Go for 3-Way 980Ti since he can obviously afford it.. Unless he decides 4k but ultrawide at 3440x1440 would be pretty cool.
There isnt really a set budget. Just looking for a high end gaming rig
I wish I was as rich as you
PC Part Picker: https://pcpartpicker.com/b/hZCypg  ProcessorIntel Core i7 6700k ; MOBO: Gigabyte GA-Z170MX-Gaming 5RAMCorsair Dominator Platinum 16GB 2400 MHz (spray painted the top part red); GPUGTX 1070 - Gigabyte Variant (Custom painted the Cooler and Fans Red); Case: NZXT S340 (Red); PSUCX 750W  (Bronze 80+); SSD: Crucial 256GB (Boot drive and for applications) and Sandisk 480GB Extreme pro SSD and a Samsung T3 1TB External USB-C SSDHDDWD Blue 1TB, Seagate 3TB (Both Run at 7200RPM); Displays: Asus something (1080p @ 144hz) and LG 27UD68-W 4K 60Hz IPSLaptop: Dell XPS 15 9550 (i7 6700HQ, 16GB RAM, 256 SSD, GTX 960M)
Hi guys I am a friend of rookie here, he has decided to make an uber pc for the sake of it. all that he wants is maximum performance but, he has no experience with watercooling or modding of any sort so could we see what you can come up with? anyone out there with the monitor setups he has detailed?
You know sometimes we forget to appreciate how lucky we are to be alive...
