make sure the front panel connectors are plugged in correctly first off if they still dont work it could be either bad ports on your board or bad case
which one to rma first is up to you
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
Would there be  a way to test which one it is?
are you sure you plugged them into the correct pins on your motherboard?
Woops lol didnt have the audio power pin connected so that fixed the atudio but one of the USB 3 ports still doesn't work
only one?
but the other does?
usb 2 or 3?
are your motherboard usb drivers installed?
