[Question] Using EK D5 PWM Pump with 8 way PWM Fan Splitter
Hi guys!
I am almost near the end of my new water cooling build, I will be posting the build log here really soon. But before that, I had a few questions.
I am using an 8 way PWM fan splitter which connects to 10 of my fans inside the case (using fan splitters). I am also using the EK D5 PWM version pump in this build. From what I understand, the pump runs only at 40% if it's running on the molex connector. Found this out after spending hours and hours trying to bleed my loop. I really wish EK had made that predominantly clear on the instructions manual. Someone from EK posted about it here: http://linustechtips.com/main/topic/363545-d5-pump-ek-xtop-d5-pwm-dead-silent/ which made me calm my nerves.
Regardless, I have the pump running at max speed, now that it's connected to both, the molex AND the PWM fan header. However, I can do that only if I go into the BIOS and set my CPU_Fan speeds to 100%. This makes all the other fans connected to the 8 way PWM splitter run at 100% too. That's not what I want. I want the pump to push as much water as it can through the loop while the fans remain nice and calm.
Is there a best-practice of connecting the fans to the motherboard via a PWM splitter so that you have control over the fans correctly? Also, how do I keep the pump running independently (@ 100%) and not affect the rest of the fans in the case? I am using a MSI X99A SLI Plus motherboard, which has a lot of system case fan headers on the motherboard.
Here's an image for a quick view:
So what do you guys suggest? Is there any way that I can keep my pump running at 100% while the rest of the fans connected to the same 8 way PWM splitter run at lower RPMs? Also, what's the best practice of connecting these fans to get the right RPMs to show up in the BIOS?
Please let me know what you folks think.
Thanks much!
E
connect your pump to the header next to the io side and the fans/other to the top right side ones you have 2 headers for fans only one uses intel specs but the pump is happy if its a 4 pin other headers follow the manuel . ps i hope you have luck with the board i owned it for all of 3 weeks its so buggy and OC with it is a nightmare . but best luck to you
