Welcome to the forum and good luck with your project! Follow your own topic.
IMO something like freelancer.com would be more suitable for hiring than this forum. You're only asking for trouble with stuff like copyright and patents going off the books...
wrong forum!
go check out deskthority.com
people design keybaords from scratch there all the time
also, im a huge fan of numpad on the left side, it means i dont have to stop using the mouse to use it, and it solves the optimal spcing of hands that a 10 keyless keyboard does
10- Keyless and no retarded looking keys, keep it simple
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
adjustable angled feet (feet that adjust with screws so that you can adjust it to a specific angle)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
No keyboard at all, design a helmet that types what you think. Do some real technical break though... can you imagine just thinkig about moving forward and strafing to the right to kill an enemy and your pc does it without you pressing any keys? Gaming by just looking at the screen... being able to use a full pc with out hands, typing school papers just by thinking your paper? That i would pay for
Edit: games could be made and designed to test brain recactions instead of eye-hand coordination.
Volume knob/wheel. The ones on the Corsair K series keyboards are a definite must have for me, and I'm sure that anyone else who has one would say the same.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
Great advices! Numpad will be included. Media buttons, play/stop and volume control (wheel thingy). Aluminum body is a must, wrist rest is included. I agree with "keep it simple".  Cheap is a must. RGB with computer program is also included.
What about size? Massive or keep it small and simple?
Also, headphones and microphone port on the side?
SLIDERS! Seriously, I would love a keyboard to have a slider for volume control, all the way to the right (Or top) is max volume, all the way to the left (Or bottom) is mute. Hate most of the other implementations of controlling volume from a keyboard.
I don't think you can do anything else that no company has already done with mechanical keyboards... Sorry but its the truth. RGB, Done. Wrist rest, Done. Cable management, Done. Macro keys, Done. Windows lock button, Done. Detachable cable, Done. USB ports, Done. Audio jacks, Done. All the good features are already available. Sorry but good luck anyways. :)
~~ Intel Xeon E5-2696 v4, Asus X99-A II, Adata 2x8 GB, EVGA GTX 980Ti FTW, InWin 303, Dell U3415W~~
Aluminum
Split
Adjustable tenting/tilt at same time
No led lighting
Matias quiet click switches
But that's just me
Full size boards present a lot of issues with size for mouse pads (which are really more important if you play FPS...) So honestly, a split board like the Ergodox infinity would be ideal.
Aluminum
Split
No led lighting
But that's just me
Why not just make it alps and MX compatible? Also, if it's a kit, you don't need to add lights... Definitely split though, and I would add that the aluminum must be coated or anodized, due to fingerprints. Also, smaller or split would make more sense for gamers, since they like to go to LAN parties, or whatever. Also, backlighting would be cool (look at GON keyboards to see what I mean.)
Also, plate mounted is a requirement, and be aware that different metals can give different feels in the plate, so offering stainless steel plates in addition to anodized aluminum ones would be a plus.
The thing is that if you want to appeal to everyone, you end up appealing to no one, because there are too many different tastes. For instance, I'm going to be building my own board here pretty soon, and it's a 60%, with aluminum plate and case (case is bronze, and plate is purple) and it's going to have some Zealio switches, along with magenta pink LEDs, and a really good PCB. Also, it's going to have some Tai Hao miami key caps.
I'm also probably going to be getting a custom hubble themed TKL here pretty soon. These are things that you can't cater to in a single board. Also, I would posit that SIP sockets are better than RGB LEDs, because you can tune the lighting you want, and you don't have to deal with any bullshit software. Macros, etc. Should all be doable on the board alone.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
Oh that 60% keyboard looks like it will be cool.
How much does it cost to make a keyboard?
I might do that.
I might do that.
Making a keyboard is very expensive, but since I plan to make them, that isn't a big problem. But, it is really expensive to make one.
I might do that.
For parts with my board, I'm close to $400 in.
Hey! New SIgnature!
Hmm.
But I have yet to find my perfect keyboard.
Apple adjustable keyboard is close, and I own it, but the switches fail, and it doesn't have enough tilt options.
Mattias ergo pro is also close.
Hmm.
why not desolder the creams and replace them with quiet click? That would make the adjustable perfect for you...
Hey! New SIgnature!
Not the same pins. I checked.
