CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£177.95 @ Amazon UK)
Motherboard: MSI Z97-GD65 Gaming ATX LGA1150 Motherboard  (£103.16 @ Scan.co.uk)
Memory: Kingston Savage 8GB (2 x 4GB) DDR3-1866 Memory  (£37.91 @ Ebuyer)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  (£49.85 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£39.00 @ Amazon UK)
Video Card: Asus Radeon R9 Fury 4GB Video Card  (£459.59 @ Overclockers.co.uk)
Case: NZXT Noctis 450 ATX Mid Tower Case  (£99.98 @ Scan.co.uk)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  (£99.99 @ Dabs)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£19.99 @ Amazon UK)
Monitor: LG 24GM77 144Hz 24.0" Monitor  (£205.17 @ PC World Business)
Total: £1292.59
Generated by PCPartPicker 2015-10-09 16:48 BST+0100
My budget is 1300, I plan on playing games at high settings and do plan on OC'ing in the future when I  can afford a better cooler
https://linustechtips.com/topic/464204-how-is-my-build/
Sapphire and MSI are both good, please don't get asus coolers for AMD its like putting more wood in fire
Get the sapphire version from the fury
The ASUS one is the only one avalible ATM and I am going with a red + Black theme
Why is ASUS not good on AMD?
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230623
like I said its like putting more wood into a fire, bad cooler
Ok
Should I get an Nvidia GPU, is there any around the same price that are just as good, I would like to stay below 1300, I wouldn't mind gimpiing my CPU for a better GPU, but would like to stay Red+Black?
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230657
Ok
what are the prices for a 980 or a 390x over there?
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230665
if you have any other questions feel free to ask ^_^
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  (£89.99 @ Novatech)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Video Card  (£509.59 @ Overclockers.co.uk)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£57.35 @ Aria PC)
Total: £1286.78
Generated by PCPartPicker 2015-10-09 17:14 BST+0100
I also have a reddit thread with this question on
This is what 1 person recommended, is it good does? It have bad parts in it?
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230754
Total: £1286.78
this is WAY better
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230763
Total: £1286.78
That card is solid. will be a beat in games...
Its expensive, but worth the price IMO
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230774
the 980 ti is the best GPU other than the titan x currently, all biases aside, and everything else seems more or less solid... now heres where my bias comes in... get the gigabyte 980ti g1 gaming :3
my first build ^~^ cpu: core i5 6500
mobo: Asrock h110-itx
gpu: r9 380
8 gigs ddr4
psu: corsair cx 500
case:thermaltake core v1
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230795
heres my current plan for 4k gaming :P
Motherboard: Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($219.99 @ SuperBiiz)
Storage: Seagate SV35.5 1TB 3.5" 7200RPM Internal Hard Drive  ($57.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card (2-Way SLI)  ($671.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($17.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($93.75 @ OutletPC)
Case: Thermaltake P5 ($160.00)
Total: $2628.74
Generated by PCPartPicker 2015-10-09 11:49 EDT-0400
gpu: r9 380
8 gigs ddr4
psu: corsair cx 500
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230802
Total: £1286.78
I would try for a bigger SSD as a 120GB will fill up in no time.
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230832
Total: $2628.74
That psu isn't the best. The newer RMi or RMx are a lot better. Also EVGA G2 is usually cheaper.
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230854
Bit too much money for me but looks brilliant
you could change the i7 to an 15, or just get one thats not skylake, then get a cheeper MOBO, such as the asus z170-gaming :P
gpu: r9 380
8 gigs ddr4
psu: corsair cx 500
https://linustechtips.com/topic/464204-how-is-my-build/#findComment-6230856
