Your Newegg link is non-clickable.
copy+paste
Still doesn't change the fact that the link can't be clicked on.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
He was showing the PCB.
OP has a Sapphire VaporX R9 290, which is not compatible with the Alphacool block he also linked. @Comic_Sans_MS showed a picture of what is not Sapphire VaporX R9 290.
I have fixed that.
I thought the Tri-X and Vapor-X was the same thing (They are NOT)
Edit- THIS will work, but derp. This topic was about passive cooling wasn't it.
@Interfectorem THIS will work, but derp. This topic was about passive cooling wasn't it.
http://site.ekwb.com/news/523/19/EK-introduces-Sapphire-Vapor-X-R9-290X-water-block/
