Its my only pc ( use it for streaming and recording )
i got barely got my laptop working Dx to make this post.
I have a PC that was working fine and decided to clean my pc case and hardware. (was allot dust in it) and replace one of my fans for the eisberg cooler due to it was making bad noise
Pc is nice and clean and added everything carefully back and decide to boot it back up. nothing. removed one of the ram cards and it worked so i thought let me add the other one back in just to make sure it broken or not. and didnt work anymore. removed it again and now nothing boots up :/
Also tried to reset cmos dont know if it worked or not did it step by step through the manual. I really dont know what happened
What more i did:
Removed everything to see if it will boot to bios.
added and removed parts fro example gpu, ram, hdd.
dont know if anyone ever had a similar issue ive been checking anything through the manual but i am completely lost now T_T
Specs:
Asus Sabertooth z77
I7-3770K OC to 4.2GHz
G.Skill 16 gb ddr3 1866mhz
CoolerMaster 240l Eisberg
GTX 780 3GB
Hope anyone could help me out, Appreciate it tho!
https://linustechtips.com/topic/462635-help-is-needed-t_t/
I don't really know too much about this kind of stuff, and can't relate to your sichuation too well, but all i can say is you should not have put the ram back in if it booted without it! Your RAM killed your board...Sorry to say it. And be careful that it didn't take anything else out with it! if it did, those parts could potentallt kill or damage the next motherbord they get put in. Hopfuly somone else can give more cheerful advice then thise. Good luck!
Computers r fun
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6208742
i dont get it tho both of them were working fine
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6208775
1 of them might be faulty,trying checking in another system,if so contact manufacturer for warranty replacement
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6208791
yeah dont think thats gonna happen lol they are all 3 years old
I did tried switching them see which one works but nothing even tried running only cpu with the motherboard to see if i can get bios running nothing.
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6208843
Motherboard 3 years old as well?
Might want to debug each part one by one
ExSystems
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6208863
any tips on ow to debug them?
  • You're gonna need to get your hands on another working pc,that is what I would have done
  • Test each suspicious part one by one
ExSystems
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6209032
I have an Asus Maximus V Formula with 4 sticks of ram. I do have one tip for you. If you get it up and running and it wont boot with the 4th stick, clean the contacts (blow on them) and change the pysical order they are in. Seemed to help me when my ram decided to be crabby one day.
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6209060
Thanks for the tip! never thought that could help but i will try it out!
Try the following:
  1. Put in the RAM stick that worked before
  2. unplug the PSU from the wall
  3. hold the On Button for at least 20 sec
Thanks for the tips ill try them out!
Thanks for the tips! sad thing is i dont have a second computer to test it on.
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6209119
@RuschGaming Mine stopped booting one day and it had a code 55 on the LCD (bad ram). I took one out and it booted, put back in and no boot ! I wanted my full 32gb so I cleaned the contacts and still no boot. Got frustrated and just switched them around to test whether it was ram or a ram slot. That worked and all 4 functioned fine. My guess is thermal expansion rubbed one contact and made a bad connection and moving them puts everything in a different point of contact between the ram contacts and slot contacts.
No offense, but GOD do I hate the shrouds on the sabertooth, cleaning that thing must be a pain !
Also if you get it working and need to talk shop, I have the 3770k too :)
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6209229
will be trying out in a few i got mad just not my lucky day lol
and for cleaning well i had no issues cleaning them lol i take my time and handle it with care ( its myu baby  LOL )
and talk shop? dont know what you mean by that
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6209367
no, blow on them first, then try it.
Be careful when blowing, if you get any moisture on the parts (Saliva) it could potentially damage them further.
If you google your motherbord error codes, you can take parts out one by one and it will give you beeps and tell you if it is posting or not, you can use that to troubleshoot your bord. If you need more info, feel free to ask...and remeber google is your friend!
Oh and, if you notice any major dust, some moistureless compressed air comes in handy.
Computers r fun
https://linustechtips.com/topic/462635-help-is-needed-t_t/#findComment-6225551
