1080p on 1440p Monitor
sillycar91
So I was planning on upgrading to a 1440p monitor soon, mostly due to productivity reasons, however, I also game a fair bit on the side. Currently I have my laptop hooked up to a 1080p monitor. My laptop is an Alienware m17x R4 with an AMD HD 7970m graphics card. I was wondering if it was at all possible to run 1440p with my computer (I am fine with not using AA and such) and if it isn't able to, how would it be to play games at 1080p instead of the native 1440p?
You should be able to run 1440p on a fair amount of (older) games, but I wouldn't count on running any modern AAA titles without turning down the settings considerably.
As for as how it looks, it depends on the game. Games with low polygon counts and low quality textures look pretty good. Games with a lot of polygons and nice textures look much more blurry.
You can, some games dont look great, but some do look fine being 1080p on a 1440p display
you can always run at lower settings, you should handle mediumish settings for all but the most demanding games
Interpolation will cause the image to not be as sharp as it otherwise would at native resolution.
if you gotta lower it you'd be better off going 720p it'll be less blurry
Rig 1 CPU: 3570K Motherboard: V Gene GPU: Power Color r9 280x at 1.35GHZ  RAM: 16 GB 1600mhz PSU: Cougar CMX 700W Storage: 1x Plexor M5S 256GB 1x 1TB HDD 1x 3TB GREEN HDD Case: Coolermaster HAFXB Cooling: Intel Watercooler
"My day so far, I've fixed 4 computers and caught a dog. Australian Tech Industry is weird."
"It's bent so far to the right, It's a hook."
Whut?
Honestly 1080p is not that bad on a 1440p display, ive done it plenty of times and even shown photographic evidence on this forum that it is not as bad as people say
Some monitors handle interpolation extremely well with only a slight loss in sharpness
I prefer to lower the settings than to set it at 1080p... so clean at 1440p.
lolwut
●CPU: i7-4790K w/H100i ●Mobo: MSI Z97 MPower ●RAM: Corsair 16GB Dominator ●GPU: EVGA ACX SC 780 3GB(X2) ●SSD: 850 Pro 256GB ●Case: 450D ●PSU: AX 860i ●Monitor: Asus PB278Q 1440p
lolwut
It's a multiple of 1440p.
The same way 1080P on 4K would look "better" than 1440.
I'm simply stating the facts.
720p may look better, with high settings
Or 1440p with lower settings
Personally I would stick to those two resolutions. It's not a CRT monitor which easily adjusts to odd resolutions
Thank you everyone for the fast response. Very helpful.
If you play 1080p in Windowed mode it will look flawless but the second you upscale to fullscreen it will look like shit(for the reasons everyone has already stated)
