Do you know any other Large cooler like Noctua nh-d15. I have been looking at cryorig r1 ultimate but the mothboard is not on comparability list. Is there another cooler in Australia which perform the same and also quiet. I getting a hperx ram kit is lowest i could found which suit any aircooler right?
Magical Pineapples
https://linustechtips.com/topic/462236-x99-sabertooth-large-cooler-compatibility/
BeQuiet. Dark Rock Pro 3
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Good but i dont really like it. Installation is annoying...  and also the result is not as good per noise ratio.
Magical Pineapples
Installation may be annoying but worth it. Also.. It is very quiet. I can tell you, you will hewr your GPU and HDD over anything in your whole rig.
I installed the Dark Rock Pro 3 recently, it was rather annoying, Noctua coolers have incredibly easy installation and I can't see any reason why they wouldn't work with the X99 Sabertooth
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
I was going to with Noctua but out of stock and not sure when it will return so im looking into other options. I know it Noctua would work, im just looking for different option.
Magical Pineapples
